I just bought an old (1974 ish) Peugeot bike for my daughter. It’s lovely. However, it needs a new front inner tube (and at some point it’ll need new tyres no doubt).
I popped into my LBS earlier to see if they had anything in stock, but sadly they didn’t. I have a few more shops to try, but thought I’d test the knowledge of STW until I manage to ring around.
I attach a photo of the bike and a close-up of the front tyre. The figures read:-
37-490 (550 38A)
Can anyone fill me in on where I might get the right size tubes for these? Amazon is ideal, particularly if there is something with next-day delivery as I was hoping to go out for a bike ride this weekend with my daughter on her new steed.
I found that website too but struggled to see the exact same numbers. There is a table half way down the page that lists ISO sizes, and in there, I can see a 490mm 550A tyre, but not really sure if that’s the same thing.
I don’t really understand the two sets of figures on the tyre wall. 490 is very different to 550.
I didn’t scroll down that far, 490 will be the rim diameter, 550 will be the approximate outer diameter (in the same way 700 used to be nominally what road bikes were). A/B/C I think referred to the width of the rim, so 700c was a skinny rim, 550A was a chunky rim, but 550c would be the same outer diameter (i.e fit in the same frame) but a bigger diameter rim with a skinny tyre.
If it is like a lot of other old French bikes, even ones originally sold in the UK. It will probably have French size threads, instead of British sizes.
M14 pedal thread instead of 9/16″ x 20 tpi .
M25 x 1 headset instead of 25,4 x 24tpi.
M35 x 1 bottom bracket instead of 1 3/8″ x 24 tpi, and right hand thread both sides.
Plus the handle bar stem will be 22mm instead of 7/8″ fit into the steerer tube.
Posted 6 years ago
Viewing 10 posts - 1 through 10 (of 10 total)
The topic ‘Vintage tyre and tube size sources’ is closed to new replies.
