Hey Kunstler,
On Android:
To set up the Buddy Beacon:
Open up the app and go to Setting in the main menu. There you have an option called Beacon. Set a pin, so that you’re not visible to everyone on the internet (http://www.viewranger.com/buddybeacon/v2/)and tick ‘send old positions’.
To start sending a beacon:
Go to the track recording page. Next to the big red record button you’ll see a little buddy beacon icon. Tap that to start emitting a signal (note you need data connection for this)
For someone else to watch you from a computer:
They should go to http://www.viewranger.com/buddybeacon/v2/ and ‘add a beacon’ (top right). They’ll need the PIN number you set up, and the email address your ViewRanger account is registered to. Once they’re in, they’ll be able to see you as long as you’ve turned your beacon to on.
For some else to see your location from within the ViewRanger app:
In the app go to Organiser > Buddy & tracker list > tap on the little ‘add person icon’ and it will ask you for their username (email address) and pin number. Enter the info, then once they’re on the list, tick the little eye/view icon next to their name (either there in the tracker list or in Organiser > Favourites).
The good news is that once you’ve added friends, they’ll be on the list and you don’t have to add them again 🙂
The ViewRanger Wiki is always a good point of reference:
http://support.viewranger.com/index.php?pg=kb.book&id=4
There’ll you find instructions for both Android and Apple.
