I’ve had this issue with Revelations when I hadn’t emptied the whole of the damper side during a service. I’d taken the top off, let all the oil out and refilled. Suddenly it was hydro-locking.
What I needed to do was, after emptying the oil from the top of the damper leg, cycle the rebound rod a few times and a load more oil came out. You don’t need to remove the rod completely (it’s a bit of a PITA to get it back in) but you DO need to take the lowers off to do this which was my mistake.
As you say, there’s just a bit of extra oil (15ml or so, at a guess) that resides under the rebound disc at normal fork extension. If you don’t remove this and simply add the standard 134ml at the top end then you essentially overfill the damper.
That may or may not be the problem for you, but I thought I had the same symptoms as you, turns out I was just doing the service a bit wrong.
