From personal experiance.. I have now stoped fitting the “towie rads” in customers homes due to constant issues… Mostly people who live in pre fabs or new buids want them and have issues with them dropping or fixings comming loose unless patress fitted beforehand.
Not to mention the inflated costs of the panels and the fact the sludge overtime builds up in the bottom due to the flow configuration internally. Yes normal rads can have this issue but its a horizontal fill if you will… Check btu rating and fit heat reflective mats behind to help…. No matter how big a rad or how good a system you have shite insulation will put all plans out of the window… Heat reading gun your friend here.
Had a customer who id fit rads for 4 seperate occasions…. Hed done his math (ex bae engineer) and he was sure he needed bigger and bigger rads… Found out there was one piece of kingspan had dropped down in his loft… Put it back and his room was like a oven.
