Goldtec, Renthal, FSA (cheapest iirc) and e-thirteen all do proper tall toothed single rings you can also fit a 9 speed chain on.
as do Blackspire etc
did you read the Velosolo site ? – their 3/32 SS MTB CR are NOT suitable for 9 speed
VeloSolo CNC Singlespeed MTB Chainring ANODIZED
As with our road rings the VeloSolo mountain bike chainrings are precision machined from the same heat treated high strength 4.0mm thick 7075-T6 aluminium alloy for extra strength. No offset so reversible without affecting chainline for longer life.
Very stiff, very strong and very round. Teeth are hobbed the old fashioned way for superb finish and performance. Classic style with machined cut-outs on 34t and 36t. The 32t is drilled rather than ‘slotted’. Minimal lead chamfer and full height teeth with no cut-outs or ‘shift pins’ give perfect engagement with the chain. Designed for singlespeed mountain bike use; on or off-road.
Available in 4 bolt 104mm BCD and 1/8″ or 3/32″ thicknesses. Choose 1/8″ with matching 1/8″ chain for a superb long lasting and strong set-up for typical UK off-road conditions (the 1/8″ width has nearly 50% more contact area for driving the chain than the 3/32″). Available in three tooth counts of 32t, 34t and 36t. Finished in anodized black and gold or custom polished. All with laser engraved logo. Please see this page for sample weights of VS components. Please see FAQ for chainring bolt advice and how to measure BCD etc.
NOTE: VeloSolo 3/32″ chainrings have a tooth thickness of 2.3mm and are therfore NOT compatible with 9 speed or 10 speed chains.[/u]
