The film is the perfect demonstration of the directional stability Volvo Dynamic Steering can offer,” explains Jan-Inge Svensson, the engineer behind the development of the system’s software at Volvo Trucks. “The stability and control are so good that you can reverse a truck over a long distance with very high precision, which is exactly what we’ve had to do in this film. It had to be perfect – right down to the last centimetre.”
At low speeds, Volvo Dynamic Steering makes steering virtually effortless and improves maneuverability. The electric motor also automatically regulates the steering and compensates for irregularities that feed through to the steering wheel, such as side winds or bumps in the road surface. As a result, the need to constantly make small adjustments to the steering is greatly reduced. Furthermore, Volvo Dynamic Steering will also automatically return the steering wheel to its starting position when released, further reducing strain on the driver.
Hmmm, maybe someone needs to get up to date with new technology before making obvious statements!
