HS33 well worth looking into.
I missed the whole V-brake thing out back in the day, i went from canti’s straight to Magura Julies.
Bought a 2011 Karate Monkey frame because it had canti studs and disc mounts, i already had a set of rim brake wheels so cheapest option was to go V-brakes.
Went with DC MX2 V’s and levers, stock pads suffered a bit from flex and caning the bike down the motorway at fort william did overwhelm them a bit, wore the pads down to the internal backing plate and scored the rims racing the MacAvalanche down Glencoe, bit worrying at times, snow, ice, mud, bog mud all laced with granite particles, but was never too out of control.
Swapped out to Aztec cartridge pads….. instant gain in sharpness and stopping power over the stock non-cartridge pads.
For weight weenism check out weights, the XTRs are a bit porky but counter that with extra power over standard V’s.
To balance things out wear wise, i have gone through rear disc pads on 3.5 runs down Cwm Carn on a wet day, front lasted into the 6th run.
There was a debate ages ago about how many pro-level xc riders would still use V-brakes if there equipment sponsors allowed them to 🙂
Half decent set of brakes, some quality cartridge pads and away you go.
If a well cheap pair of XTR’s came my way and the pivots weren’t worn out and sloppy i would whack them on and have a go.
