Using SLR Camera in...
[Closed] Using SLR Camera in the Snow
[#1194674]
Any suggestions for a bumbling novice on the best way to shoot in snow with light cloud cover or sun?
I've just inherited an Olympus E510 digital SLR and have been trying to get to grips with it with mixed results.
At the moment I'm getting quite frustrated as the snow is creating some epic landscapes but I just can't seem to capture them on film.
Posted : 07/01/2010 9:40 am
 cp
your problem is trying to use film in a digital camera 😉
Posted : 07/01/2010 10:05 am
Dial in an EV of +1.5 - +2 (the camera gets confused by all the white and under exposes). Ideally take photos at sunset and sunrise (assuming there's no cloud cover). I wish I'd taken my camera this morning, it was epic.
Posted : 07/01/2010 10:06 am
Are the piccies coming out too dark so the snow looks grey? If so, spot meter off a bright patch of snow, dial in +2EV of exposure compensation and give that a whirl. Take a pic, check your histogram, tweak exposure to suit and away you go.
Oh, and trying to capture landscapes on film with a digital camera won't help either 😀 I'll get me coat.
[edit: me type too slow]
 cp
as a slightly more sensible answer, you need to over expose images, as the white snow is confusing the metering system. Very simply, a camera tries to get the scene to an average specific shade of grey (if it was a b&w image, which essentially is what the meter sees). So as there is so much white snow, you need to over expose the image. in doing this, you generally keep the shutter open for longer... assuming you are in Aperture priority or another program mode, you can probably adjust this easily, but may need the manual to get the specific combination of key presses.
Posted : 07/01/2010 10:09 am
Thanks all. Will try these tips out (as soon as I drag my carcass out of bed). I've obviously got lots to learn, particlulary using film in a digital camera, I thought it felt wrong shoving 35mm in that little slot on the side!!
Posted : 07/01/2010 10:14 am
 Smee
Does the camera have exposure lock? If so meter using the sky. Point to sky, press shutter release halfway down and hold it there, compose shot, press shutter release fully down.
Posted : 07/01/2010 10:17 am
I think it has exposure lock (AEL?) so that could be useful.
Posted : 07/01/2010 10:23 am
That won't work. EV +2 is where to start.
Posted : 07/01/2010 10:25 am
 Ewan
If you meter on the sky you'll underexpose even more - the sky will be the brightest thing around. Just overexpose by a stop or two.
Posted : 07/01/2010 10:30 am
In addition (nothing beats getting the correct exposure right off, but I often can't be bothered to meter correctly if in a hurry) -there are two quick ways to get an idea of how things work-
Shoot in raw- this gives greater latitude to adjust the exposure in software- take a few shots as the camera exposes them, then adjust the exposure in software using Olympus camedia, photoshop, Capture One or whatever software you're using- you'll need a raw converter that handles your camera's output, most of them should do so. This will help you understand the effects of adjusting the exposure, and give you a guideline of what adjustment needs to be made.
The second way is to bracket the exposure- your camera will have a setting to take multiple shots at the same time over and under exposing each shot off it's metering, giving you a set of photos to pick from.
Posted : 07/01/2010 10:33 am
I had the same problem the other day, then started reading up on how cameras meter light (i.e. they only see a mid-grey so have to compensate etc)and realized that I would have to overexpose as said abouve - but as a novice, I've a couple of questions:
1. What does EV stand for?
2. Do EV steps i.e. 0.3, 0.6, 1.0 etc etc relate to f-stops? and therefore does say dialing in EV+2.0 only affect the aperture size or does it adjust a combination of aperture, shutter speed and ISO?
3. Could anyone heer please give me a simple step guide to taking a landscape picture?
cheers
back in film days you were meant to make the camera over expose (2 stops perhaps) so the snow looks white and not blue or gray. Film days, the saying was - Expose for the shadows, develop for the highlights.
It can be risky to over expose digital as highlights will be lost forever so I'd be more inclined to fiddle with images on the PC after exposing for highlights.
"Expose for the highlights and develop for the shadows" (for digital)
Posted : 07/01/2010 10:35 am
Bracketing is the answer - at least at first.
Posted : 07/01/2010 10:36 am
[i]Just overexpose by a stop or two. [/i]
Does this mean adjust the EV or the axctual aperture?
Posted : 07/01/2010 10:39 am
There's a great book called 'Understanding Exposure' which covers the whole aperture- shutter speed- iso triangle really well.
It's available on Amazon, or there's a scanned copy available in the usual suspect torrent sites, but it is really worthwhile buying.
Posted : 07/01/2010 10:40 am
@yoshimi: EV relates to "units" of exposure. One way to get an extra 1EV is to open the aperture 1 f stop. Another way is to half the shutter speed. By dialling in an exposure compensation in EV, you are just saying to the camera "whatever you think of the light here, you're wrong by x amount - so now give me an exposure appropriate", by changing the aperture, shutter speed, or both, according to the P, A, S setting you chose.
Hmmm ... probably that doesn't make sense ...
Posted : 07/01/2010 10:41 am
1. Exposure value.
2. The f-stop remains the same but the shutter speed is altered to overexpose (+ ev) or under expose (- ev) compared to what the camera 'thinks' the exposure should be. All bracketing does is take 3 pictures at -ev 0ev and +ev (you select how much + and - ev is used, -2 0 +2 for example). Pointless in snow because you know you need +ev. +2 is the rule of thumb.
2. Counter-intuitively you need to focus on something close otherwise the foreground will be out of focus. To get the whole picture in focus you need to know a bit about hyperfocal distance. Have a read of this:
[url= http://www.dofmaster.com/hyperfocal.html ]http://www.dofmaster.com/hyperfocal.html[/url]
Then have a look at this:
[url= http://www.dofmaster.com/doftable.html ]http://www.dofmaster.com/doftable.html[/url]
Posted : 07/01/2010 10:46 am
If you are using A mode, tehn if you change teh aperture the camera will just cancel out your change with a different shutter speed and the resulting picture will look the same, so you would need to change EV setting.
If you are using M, then you set the aperture and shutter to what you want, so for example, set it to what the camera suggests, and then open up the aperture.
In general, changing the EV works.
Posted : 07/01/2010 10:47 am
Exactly. The net exposure will always be the same unless you override it with the EV setting.
Posted : 07/01/2010 10:48 am
EV = exposure value, which is a measure of light intensity where adding one EV = doubling intensity = 1 stop in aperture terms. Digital cameras usually break each stop into 3 equal parts: 0.3, 0.6 & 1. So one EV more exposure would be halving* the shutter speed or dividing the aperture by 1.4 (actually square root of 2) eg f4 to f2.8
* eg 1/500 to 1/250 actally doubling the time, as exposure is in reciprocal seconds 🙂
Yoshimi - if your camera is in P, S or A modes just dial in a value of over-exposure and let the camera get on with it. It will take the 'correct exposure' values for shutter & aperture and adjust them accordingly to over-expose by the quantity you have requested.
I would start at +1 and take it from there.
If you are in manual mode, then either increasing the shutter speed or opening the aperture (smaller f-stop) will tend to over-expose (or adjustng both, of course). I generally take a shot in P-mode to get some base settings and then adjust from there. The meter in the camera should still tell you if you are under or over-exposing; most camera have a little bar graph that will either go towards -ve for under-exposure or +ve if the shot will be over-exposed.
Posted : 07/01/2010 10:49 am
DrJ - that does help
So 1EV = 1 f stop
Therefore if as above someone says adjust by 2 f stops, this can be done by dialling in EV+2.0
A top tip I once read about photographing snow was to find contrast. Whilst an icing sugar frosting over every surface looks beautiful, it is difficult to convey it in a photograph. Try finding some dark surfaces too (such as a row of trees) to get that contrast you need.
Just bought a Canon 450d and am deturmined not to use the muppet auto part of the dial(Landscape, sport, portrait etc)
Aperture priority set, then, and attempting the EV compensation of around 1.5 and he snow is burnt out, my images are blurred - I just aint got it.
Mrs imp sticks it on the muppetist setting on the thing(Green square) and hey presto - Nice looking images.
Its going to take a while I reckon.
Posted : 07/01/2010 10:50 am
All bracketing does is take 3 pictures at -ev 0ev and +ev (you select how much + and - ev is used, -2 0 +2 for example). Pointless in snow because you know you need +-ev. +2 is the rule of thumb.
Not pointless because:
+2 is a rule of thumb, and not guaranteed to work in your lighting conditions
suitable bracketing will assure you of a correct exposure (with a lot of wasted frames, to be sure) e.g. I have it set to take 7 shots, 0.7ev apart.
you can get more sophisticated and bracket around the value you want, say around +1, or whatever
You can think of it like that if it helps, but the aperture isn't changing, it's the shutter speed.
OK, pointless is a bit harsh maybe. Setting the EV and a quick glance at the histogram would be easier (for me anyway).
Posted : 07/01/2010 10:51 am
Drop to +1 if the highlights are blown, although if the contrast is high you may be stuffed.
The blurring is because of the increased shutter time. Have a look at what shutter speed was used and adjust ISO to get it to at least 1/focal length.
Posted : 07/01/2010 10:56 am
why make things hard for yourself? Those numbers have little to do with actual images apart from depth of field issues
Posted : 07/01/2010 10:57 am
Sorry my last post bit slowe there
Cheers for all your help - I'm currently reading a fairly basic photography tutorial book along with the camera manual, but I'm finding myself re-reading pages over and over again so its pretty slow going and things aren't explained that well. Such as when EV is refered to, it doesn't say this means exposure value. lots lots more reading and practicing to do!
Just this has helped me understand
[i]If you are using A mode, tehn if you change teh aperture the camera will just cancel out your change with a different shutter speed and the resulting picture will look the same, so you would need to change EV setting.[/i]
Along with this
[i]Digital cameras usually break each stop into 3 equal parts: 0.3, 0.6 & 1. So one EV more exposure would be halving the shutter speed or dividing the aperture by 1.4 (actually square root of 2) eg f4 to f2.8 [/i]
Posted : 07/01/2010 11:00 am
Unless you're in Shutter Priority (the S of the PSAM modes) in which changing the EV will alter the aperture.
Posted : 07/01/2010 11:08 am
As mentioned above, EV is exposure value and is a combination of aperture and shutter speed. For a landscape shot you want to fix the aperture at something suitably small (f8-f11 fine for a crop sensor camera - good depth of field without diffraction effects softening the image).
Then, to add +2EV you can either:
1. Set camera in aperture priority mode and then dial in +ve exposure comp using the dedicated function - this usually just tells the camera to increase the shutter speed
2. Set the camera in manual, adjusting the shutter speed until the needle on the light meter in the view finder is to the right of the centre mark by the required amount of EV's (stops)
Unless you are taking a meter reading from the brightest patch of snow (ie. by using spot metering), dialling in the +2EV exposure compensation will more often than not result in blown highlights. Metering the whole scene, which will invariably be darker overall than just a patch of bright snow, will require less exposure comp to be added.
And forget all that bracketing nonsense with digital, unless you want to blend exposures later - use the histogram, that's what it's there for.
And if you can't be bothered working out hyperfocal focussing distances, if you are using a suitably wide angle lens (I dunno, up to about 24mm say) just focus on a point 20-30ft ahead. The rule of thumb is to focus a third of the way into the scene but where a third lies is often open to interpretation.
Posted : 07/01/2010 11:12 am
Yoshimi, I'm with you on the determination to learn how to use the bloody thing, snd it's most definitely going to take a while.
Still, its a good way to waste time whilst supposedly looking for a job!
Posted : 07/01/2010 11:13 am
Don't "those numbers" pretty much define everything about the image, apart from the actual composition itself? (depth of field, bokeh, contrast, brightness, colour, grain, sharpness)
Posted : 07/01/2010 11:14 am
Have to disagree (again) Bracketing is quick, foolproof, and (with digital) free.
Posted : 07/01/2010 11:15 am
Checking the histogram gets you to the right result quicker, without checking through god knows how many images once you've down loaded them all 😉
Posted : 07/01/2010 11:16 am
Seriously, thankyou all, this has helped lots - cant wait for weekend to try a few of these ideas out 😀
Posted : 07/01/2010 11:18 am
'histogram' not even going to ask about that yet - I've seen them but don't know what they are....something for further down the learning process I think.
jbig - good luck, think we'll need it:)
Posted : 07/01/2010 11:21 am
@Dudie - you do it your way, I'll do it mine 🙂
The histogram gives a distribution from the whole scene. If it's a once-in-a-lifetime shot, that may have small elements in it I want to be sure are properly exposed, then bracketing gives me that (near-) certainty.
Posted : 07/01/2010 11:22 am
Stick it in manual mode and get used to it, would be my opinion. I spent almost all of yesterday shooting in manual with no probs at all (first time I've ever shot at ISO100, F9, 1/4000th and still got a lovely bright scene!
Having said that, when I put mine in "shoot fast things" auto mode for the missus and I to get shots of sledging without thinking too deeply and it seemed to produce perfectly nice bright images despite the snow, it uses centre-weighted metering for that IIRC.
I use bracketing for blending mainly, rarely for getting the correct exposure, but it is handy for those shots you can't afford to miss (takes time to chimp over the histogram).
Posted : 07/01/2010 11:31 am
Just tried a couple of shots in the garden. Better, but still not quite there, but there's loads more tips to try out yet.
Its like adjusting your gears though, you get it almost right then keep adjusting, it gets worse again but you can't remember how you got to the good spot in the first place!
I'll stick at it though.
Posted : 07/01/2010 11:32 am
Never really seen the point in manual mode for every day shots. The only time I really use it is for long (bulb) exposures or for stitched panoramas.
Posted : 07/01/2010 11:39 am
 Rich
Good tips guys.
When I photograph snow it comes out blue (Sony A200). Will overexposing cure this too?
Sounds like a White Balance problem ?
Posted : 07/01/2010 11:40 am
Haven't read the whole thread in detail, but if no-one's mentioned a polarizing filter yet, I'll do it. If you find your skies are looking washed out and not showing cloud detail, a polarizer can help a lot. Snow, clouds, water shots, a polarizer will always make a big difference. Won't fix exposure problems though.
Posted : 07/01/2010 11:52 am
