URL links in the fo...
[Closed] URL links in the forum - a question (and a suggestion maybe)
[#2144170]
Is it possible to get links set up so that when you click on them it automatically opens a new tab/window (like they do on Retrobike for example)? I know it's not hard to right click and open in a new tab, but it'd be schweet with you could just click on a link and have it do this rather than going straight to the url in the window/tab you're already in (ie. leaves STW forum)...
Am I the only one who finds this a little niggling & annoying? 😳
Posted : 31/10/2010 4:57 pm
A vote from me to leave it the way it is - thanks.
Window proliferation? Nein Danke!
Posted : 31/10/2010 5:02 pm
I would like it like the OP
have to hold CTRL down and click at the moment
Posted : 31/10/2010 5:03 pm
well, it's more tab proliferation if you're using the latest browsers...
Posted : 31/10/2010 5:04 pm
ah, hold CTRL down, didn't know about that trick! cheers 🙂
What about having choice? Those who want a new tab can right click, those who don't, don't.
Posted : 31/10/2010 5:05 pm
that's how it used to work, pre-hack, though it doesn't conform to normal webpage usage, which is why I suppose it was changed. In Firefox it should be possible to write a greasemonkey script to modify all the links...
Posted : 31/10/2010 5:06 pm
on most browsers you can middle click to open in a new window or tab
Posted : 31/10/2010 5:07 pm
How much time are you pending on forums???? 😮
Posted : 31/10/2010 5:16 pm
here's the Javascript required:
foo=document.getElementsByTagName('a')
for (x in foo) if (foo[x].host != "www.singletrackworld.com") foo[x].target='_blank'
Posted : 31/10/2010 5:21 pm
firefox - middle click to open in new tab.
internet explorer - middle click to open in new tab.
non?
Posted : 31/10/2010 5:48 pm
Chrome - middle click to open in new tab
Posted : 31/10/2010 5:49 pm
didn't know that either! so, no need to change anything, just a need to educate meself betterer re. internet and mouse usage! 😳
Posted : 31/10/2010 6:00 pm
I changed by greasemonkey script slightly:
len = foo.length
for ( x = 0; x < len; x ++ ) if (foo[x].host != "www.singletrackworld.com") foo[x].target='_blank'
and it works fine making all external links open in a new tab
Posted : 04/11/2010 12:04 pm
Just used middle button for the first time (possibly ever)- it works as advertised, doesn't it 🙂
Posted : 04/11/2010 12:15 pm
Well, I don't have a middle button, so have to right click then choose an option.
Why is defaulting to open in the same tab letting the user decide any more than automatically open in a new tab? You can override both options. I know technically it's a web standards thing but can't help feeling it's not so relevant now tabs are around
Posted : 04/11/2010 12:21 pm
