Unplumbing a washin...
[Closed] Unplumbing a washing machine
[#3098642]
Giving the keys back to our rental today. We've moved our washing machine out but the drain goes into the U bend under the sink. Need to get some sort of cap/plug/stopper to avoid contents of the kitchen sink emptying into cupboard below.
Any idea of the name of the bit I need to look for? There are threads on the end but originally it was a u bend where you have to cut the end first, so no plug supplied originally.
Posted : 31/08/2011 7:09 am
Take a pic & a measurement. Plumbing centre chaps can usually sort you out. Failing that a cork. 🙂
Posted : 31/08/2011 7:12 am
plastic bag and a rubber band over the spigot.
Posted : 31/08/2011 8:30 am
^^ what stoner said.
Posted : 31/08/2011 9:59 am
Don't bother*, previous tennants in my house didn't, I didn't find out untill the previous contents of the sink started to rot in the cupboard!
*tongue in cheek
Posted : 31/08/2011 10:04 am
 Taff
An effErvescent bottle with some tape fits a treat! Otherwise go to B&Q and get a stop. Just ask someone in te plumbing dept and they will show you
Posted : 31/08/2011 10:24 am
A cork?
Posted : 31/08/2011 10:28 am
Taff - experience with B&Q/Wickes plumbing department tells me you need to know exactly what to ask for otherwise they're useless hence the thread.
thisisnotaspoon - the previous tenants had done that, first time I pulled the plug I emptied the contents into the cupboard below
druidh - unfortunately the bottles of wine I buy don't possess corks big enough to plug the hole (well in fact most don't possess corks at all)
Anyway, thanks all, found local plumbing merchant who opens at 7.30 am who found me the right bit
Posted : 31/08/2011 8:40 pm
Dont forget the washing machine is still holding water, so when its outside, let the hosed drain onto the floor, or plug into the mains and let it spin , dont connect to the water supply though.
Makes it lighter to carry as well.
Posted : 31/08/2011 8:44 pm
