Understeer or Overs...
[Closed] Understeer or Oversteer
[#1502228]
So, I am approaching a very sharp but very wide corner... a switchback I guess. I lean...turn in.. whatever instinct tells me to do and I suddenly realize I have zero confidence in my front wheel going where I want it to go, I am sure it is slipping as I am often making very urgent quick corrections.
I guess this is understeer, but am happy if I am corrected. I also guess that playing with the position of my bars might help.
Any pointers?
Posted : 12/04/2010 9:03 pm
Understeering meens your front wheel pushes forward, dispite you turning the handlebar. Oversteering means your rear wheel breaks loose.
Posted : 12/04/2010 9:06 pm
Tyre pressure/wear/type? always worth considering.
Bar position might make a difference, getting more/less weight on the front-same for length & rise of stem.
Rider position, weight distribution etc. all play their own part
Posted : 12/04/2010 9:09 pm
So it is understeer.
Any tips on what to try?
Posted : 12/04/2010 9:10 pm
 jedi
your feet, body and where you look will have a massive effect
Posted : 12/04/2010 9:21 pm
Don't know what bike your on but if its a f/s its also worth checking out your shock setup. If you have no grip at the rear (eg overdamped and packing down)this also translates into no confidence turning in.
Posted : 12/04/2010 10:14 pm
Maybe your just wicked and riding too fast into bermz and the tyrez cant keep traction with your amzing ability?
Posted : 12/04/2010 10:20 pm
Understeer you see what your going to hit, oversteer you dont lol
Posted : 12/04/2010 10:23 pm
Leaning in and turning in are two different things and are very different in effect.
Leaning the bike produces camber thrust and turns independent of steering angle
turning the bars to the left moves the centre of gravity to the right and gyroscopic precession tips the bike to the right
speed has a huge affect on this camber thrust and gyroscopic precession and tiller action / steering angle are all effects that are real
if we had to think how it works we would all fall off our bikes - even Jedi
A switchback goes up and down in a straight line in English
Its an awfully complex thing to untangle in words get someone who really knows to watch you and they will see what is happening n a tenth of a second
Posted : 12/04/2010 10:29 pm
I'm with TJ here, you wouldn't really be turning the handle bars to steer, unless you are going really slow - instead you lean.
If going fast through switchbacks you should countersteer - turn the handlebar the 'wrong' way in order to tip the bike over faster (motorbikists do this).
If the front wheel is washing out / understeering would that be because you've got your weight far back? I was told to put your weight central and through the outside pedal and inside handle bar.
Oh and point your head and shoulders at the exit of the corner - and you magically go there.
Posted : 12/04/2010 10:38 pm
 Bez
1. a flick of countersteer on the way in, it drops your weight into the corner
2. drop the inside of the bike down but keep your shoulders level
3. get your balls as close to the stem as you dare
add 'pro elbows' to taste
sorted
Posted : 12/04/2010 10:47 pm
flamin 'ell TJ goes all Yoda on us..
Posted : 12/04/2010 10:59 pm
Hey ho soulrider if you had to describe what you did could you still ride a bike? Where wher eyou this weekend anyway!
Gyroscpic precession and camber thrust are two horrible concepts that enable you to ride
i defy anyone to describe them in words easy to understand! I know whats happening and can demonstrate it but cannot explain it in text ( can't do it at speed either - I diagnose lack of bottle on my behalf)
Posted : 12/04/2010 11:06 pm
