I sympathise…Crests are a royal PITA. Someone else (Mavic?) needs to make a lightweight rim that fits tyres properly….lot of threads with people with the same problem on here. I even heard that a major wheel supplier is complaining about it.
The problem is, they don’t advertise it but Crests have been made larger than normal to make them easier to run standard tyres tubeless. “Tubeless ready” tyres (like yours, I presume) have been made tighter than normal to make them easier to run tubeless on standard rims. So the two in combination make for a very tight fit.
You have 3 options:-
1) change your rims to something else: Expensive and crests anything else is probably heavier.
2) Change your tyres: You might be able to find something (non tubeless ready) that fits better. I tried Panaracer Fire XC Pro 26×2.1 on 26″ Crests and they went on with thumbs no problem.
3) Carry on with the Aligator wrestling: Warm soapy water, washing up liquid, gt85 on the bead to help it pop into place etc. Of course this is fine indoors, what about when you get a puncture on a cold, wet night ride?
