The Flows are overkill strength-wise but I like the width. Unfortunately the lighter Stans rims are much narrower. Rim stiffness is maybe another factor to think about but is often overlooked. I’m not sure what the correct answer it, it depends on too many factors (your weight, how hard you ride downs, how fit you are, technique, where you ride, tyres etc).
I would suggest that unless you’re pushing hard then you probably won’t see too much of the benefit of Flows, and they will weigh you down unnecessarily.
There is very little difference between non-tubeless and ‘tubeless ready’ tyres. Some tyres work better than others for tubeless but there’s not a lot of correlation between how easy they are to get inflated and what it says on the sidewall. Once inflated and sealed there’s no real difference. (I’m not talking about UST btw).
