Turner flux dw fork...
[Closed] Turner flux dw fork choices
[#3640480]
can I ask what people are running- is it more popular to run 120mm, has anyone done both? Thanks in advance
Posted : 03/02/2012 5:50 pm
 nbt
Mrs NBT has been running rebas at 100mm. Have just increased the travel to 115mm (they're 2007 model so later models go 100-120). FIrst ride on longer travel forks should be this sunday....
Posted : 03/02/2012 5:52 pm
I've got some 120 reba uturns
Posted : 03/02/2012 6:05 pm
RS SID RLT Ti 120mm, 15mm axle on mine. RS Reba Race 120mm QR on ar lasses.
Posted : 03/02/2012 9:10 pm
Fox F120 on mine. Sorted.
Posted : 03/02/2012 9:22 pm
yes I was thinking of a f120 due to superb reliability Ive had in last 7 years of fox forks- I could always have spacers added if I change my mind
Posted : 03/02/2012 9:24 pm
 AD
Pace RC39's on an '09 DW Flux. Absolutely spot on from my point of view but will probably replace with 120mm forks when they finally die.
Posted : 03/02/2012 9:26 pm
120mm for certain. Personally I prefer rockshox, so I've got SIDs on my flux.
Posted : 03/02/2012 9:32 pm
Hi
I run Rockshox Revs U-turn on mine mostly as I already had them.
Set on 120mm most of the time but have wound them out to 140mm for extended downs eg Garburn Pass, Whinlatter etc.
I know I probably shouldn't but there you go-it's awesome.
Have been thinking on some Fox 120 but not sue its worth the expense
Steve
Posted : 04/02/2012 11:57 am
