It can be tricky nailing where the play is: so drop the rear wheel off and the shock top bolt.
You can usually see the wiggle in the Rocker Tip area moving by grabbing the seat stay and pushing around. Fix those first with a shim – on mine it was only actually one side – the right hand side. I’ve fixed three Turners in this area with a shim.
When you’ve sorted that, it’s worth checking the Main Pivot so whilst the Rocker tip bolts are out you can check for side to side play there, again I fixed with a shim.
Finally when you’ve got the Rocker Tip Bolts and Main Pivots free of play and tightened up, check for movement in the DW-LINK itself. Tricky to work out which bush but a bit of tightning and loosening allows you see where movement is. Whip out the bolt and hardware and put in a new bush. Again the right hand side seems to be suspect. At this point I realised the shims included didn’t fit the DW-LINK area. So luckily just a new bush solved it.
This is the order I did it in, wear (or poor fit) almost certainly occurs on the Rocker Tip initially. Between myself and a few mates, 4/5 bikes have had shims here. All good now.
Here is a picture I used for reference
http://www.turnerbikes.com/turner-pdf/tech/czar-1-0-torq-setting-nm-2.pdf
Interestingly I and GF have a pair of fluxs and czars, none of hers have had issues at all. So I’m putting it down to my added weight and extra male testosterone creating more havoc!
