There’s the Jet Black Dynometer Turbo Trainer.
And there’s also the new Elite Qubo Wireless.
The Jet Black got a bad review in the cycling press.
The Elite Qubo got a good review. It was within 10% for accuracy when measured against a powermeter.
Trainers at this level just use calibrated resistance curves to calculate power.
Power curves for most trainers can be found if you look on the internet – but the accuracy often depends on things like – rider weight, psi in the tyre and temperature of the turbo trainer.
The most important thing is consistency as a measure.
There is a very good alternative using a USB ANT+ stick and an ANT+ cadence device – called trainer road (subscription based).
It uses power curves of turbo trainers to display power.
