Right, after 5 or 6 years biking I’ve finally decided to go tubeless, – have a couple of questions that I know may seem a touch on the stupid side…
Have myself a Mavic Crossmax Enduro wheelset and and a 2015 Schwalbe Nobby Nic for the rear, and Hans Dampf for the front, both 2.35, both Evo Snakeskin Tubeless Easy.
Couple of Questions
– Should you be able to inflate without any sealant? – think I remember coming across someone recommending to do this, as a kind of preliminary test, and then deflate and add sealant and re-inflate. – This might have been for a UST tyre though. I’ve tried anyway, and it seems to me like there is no hope of me inflating, at least wthout sealant.
– The tyre feels a bit loose on the rim, particularly so when it is in the centre channel, as recommended by Mavic. Can’t see it inflating this way (granted I haven’t actually tried with sealant yet). Any tips or alternative ways of doing it?
If the answer to both of the above questions is “you definitely need sealant” to have any chance of inflating, then that would be useful to know, – because nothing is infating right now without it at least. Alternatively, if the answer is that generally you should be able to inflate, though it might not stay inflated for long, – then I might need to try a different tack, – perhaps popping in one side first with a tube.
