Got my new wheel all setup, maxxis minion dual ply on stans flows, using stans sealent, yellow tape and a valve. got them inflated with a compressor and seem to be sealed OK, 3 days later and no loss of pressure, from the thumb pinch test anyway, (not had chance to ride the wheel properly yet) but there's spots of clear fluid forming on the sidewalls, almost like the latex is staying inside but the pressure is pushing the water (assuming sealent is water based) thorough teeny tiny holes in the tyre carcass. I've dropped the pressure a bit so it's definitley under 40psi
Should I be worried? Anyone else seen this?
