Wa gwan.
After a bit of over-enthusiastic hardtail schralping, I’ve put quite a good flat spot in my nice Spank rim along with a healthy wobble.
It’s in the truing stand but I’m torn.
It seems I can either get the spoke tension fairly consistent via the pluck test or, I can get it relatively true but with more uneven tension.
I mean, I know that even tension is the most important but should you compromise on a damaged rim?
Is the rim basically toast?
Should I just settle for even tension and a big wobble over a straighter rim?
Is there anything you can do to straighten a rim BEFORE you then go and tension it up again?
Any tips for dealing with this? I’ve built a few wheels now but not really repaired any as such.
The compromising is difficult 😕
