Trek Fuel EX Bearin...
[Closed] Trek Fuel EX Bearing Service
 P20
[#1955429]
There's some play in the swingarm, mainly under braking. Has anyone got a service guide for these? Cheers
Posted : 02/09/2010 7:22 pm
 P20
Anyone?
Posted : 02/09/2010 9:39 pm
maybe tighten all the bearing bolts and shock mounts to stop the play. If that doesnt work youll have to just kock the bearings out and press some more in
Posted : 02/09/2010 9:43 pm
I have just done mine the other month. Its just a case of taking things apart and tapping out the old bearings. the baerings in the ABP and rocker are all standard that you can get from any shop. The main bearing(one just above Bottom bracket) is a special. I would suggest going down to a trek dealer with your recipt as the main bearings are life time warrenty, before you take any thing apart. I was lucky and only had to wait two weeks for new bearings but in some cases you have to wait longer.
Posted : 03/09/2010 12:44 pm
