Viewing 9 posts - 1 through 9 (of 9 total)
  • Travel adjust on Rebas…
  • no_eyed_deer
    I'm looking on the flea-bay at the moment for a set of Rebas (idealy the 'team' model, in silver). Are all the various variants from say, 2006-2008 travel adjustable?
    …And is the adjustable travel range the same on each model?
    I'd be looking to run them in the range 80 – 100mm (ideally 80mm), but some of the ones I've seen say they are 110-115mm travel, or something like that.. Would I be able to reduce the travel on these ones to 80mm?
    Confusing..
    Cheers!
    PeterPoddy
    Yes. You have to strip the air cartridge and add a spacer to reduce the travel. All Rebas can be done like this.
    steve_b77
    You don't even have to remove the lowers / air cartridge.
    – Let all the air out of both chambers.
    – undo the top cap – 24mm socket.
    – undo the 5mm allen bolt in the bottom of the LH leg.
    – compress the fork (catch the oil out of top & bottom).
    – slot a spacer in on the shaft.
    – put back together.
    – simplez.
    PeterPoddy
    Steve, that's a good way of doing it! Nice tip I think!
    timdrayton
    that is a good tip,
    does that work for increasing travel, ie do they all go up to 115, if mine are 100mm will there be a spacer to remove to go to 115?
    timdrayton
    no_eyed_deer drop us a mail might have some 2007 reba races in a day or so?
    laura.pell1@ntlworld.com
    no_eyed_deer
    Cheers for the info..! but, sorry to be pedantic, just to clarify – do ALL Rebas go down to 80mm?
    @ timdrayton – I'll send you an email..!
    julianwilson
    tim, iirc there will be a 15mm spacer in your fork (behind the topout bumper) that you remove: this lets the fork extend to 115mm then.
    The sram service guide pretty much explains it all.
    edit: no reason why any (normal not air u-turn) reba couldn't go down to 80mm if you put another 20mm spacer in.
    glenh
    Pre '09 rebas: 85/100/115mm
    09: 80/100/120mm
    All adjusted with spacers (unless they are a u-turn model).
The topic ‘Travel adjust on Rebas…’ is closed to new replies.
