Viewing 7 posts - 1 through 7 (of 7 total)
  • Towbar Carriers
  • simmy
    Is there any carrier that doesn’t use the main towball and still allows a caravan to be towed ?
    Asking for a friend. I think the bike will be squashed between car and caravan.
    sparky1uk
    Yes. Speak to Pendle.
    Pendle Wheel support rack for towing
    wheelie
    Maxxraxx…I have a four bike one if interesed
    antigee
    think that even though not directly on the towball the weight of the rack plus the bike(s) will add to the nose loading – depends what they are towing with / towbar spec
    mikewsmith
    So he’s towing a large trailer and is not sure where to put his bikes?
    The high wheel thing looks like a low of weight on the towbar.
    coolhandluke
    My towbar carrier has a metal plate that is sandwiched between the ball bit and the chassis bit.
    You just need longer bolts to put it on but once on, it stays there.
    A pole goes into the plate thing and the bikes hang from it.
    I don’t use it any more so you can have it for £20 if you can collect. 3 bikes fit. It’s a Witter one.
    Wigan.
    dibboid
    Just mount some roof bars to the trailer and do it that way. I’ve seen loads like that. 🙂
The topic ‘Towbar Carriers’ is closed to new replies.
