I rode NCN 72 CTC last year, used Anker as mentioned and the crossing took me 4 days, 3 overnight stops. Used Garmin 1000 for nav with brightness turned right down but TBT on, Garmin had 70% charge left on day 1 so I didn’t recharge it for the second day, Phone still had 90% charge until the evening when I made a few calls, day 2 Garmin had an issue finding satellites so chomped about 20% but still 40% left at end of day but I did recharge it because the next day was the bumpy bit Hexham way and just wanted to feel comfortable following the right route as it twists and turns a lot around Hadrian Wall, recharged Anker and Phone and Garmin that night, day 3 Garmin had 60% left at end of day, phone 90% so didn’t bother charging either for the last day as it’s a fairly easy pootle along cycle paths and small B roads. Also, I always turn of wifi on phone unless the 3/4G signal is pants then I use BnB/Hotel wifi for calls etc.
Did a Tour of the Dutch Classics with same setup, 6 days of riding and using similar setup produced similar results of usage.
