Viewing 3 posts - 41 through 43 (of 43 total)
  • Too much oil in the car and now it's stopped working.
  • Frankenstein
    My old man overfilled mine a bit and caused oil leaks in the rocker cover (new gasket and sorted).
    Far too much oil? Drain (some) of the oil when engine is cool/cold.
    glenh
    MidlandTrailquestsGraham – Member
    A bit of oil getting pushed into the inlet won’t trouble a diesel…
    http://en.wikipedia.org/wiki/Diesel_engine_runaway
    http://www.youtube.com/watch?v=5zx3qKX_Pno
    Yeah, I said ‘a bit’, not half a gallon 🙂
    Doesn’t that normally happen with blown turbo oil seals anyway, where the turbo is blowing oil into the inlet, rather than a little overspill?
    Edukator
    A litre over a sump is about 2cm and will make naff all difference even if you really throw the machine around. Engines are designed to cope with overfilling, oil surge and being run a bizarre angles.
    An old gneration Cooper S I had with minimalist piston rings had quite a thirst. Overfilling by a litre meant it would just about get to the next prtrol fill up without running dry (a cental pick-up pipe helped).
The topic ‘Too much oil in the car and now it's stopped working.’ is closed to new replies.
