my bottlerocket has a 30.0 seat post i want to get a 30.9 uppy downy posty wosty, so should i get it reamed or go the 27.2 route with shims?
ta
ta
That's a lot to take off!What's the wall thickness?
Being a transition its probly about 5mm!
dunno
Shims
What size seatpost clamp?
shims...the metal is not thick enough to withstand the removal of 4.5 mm IMHO. you would be removing over 50% of the metal if not it all IMHO.
dunno 2010 bottlerocket
tricky one!
will you be raising and lowering the post in the frame too? or is the 125mm adjustment gonna be enough for all your riding? if the latter I'd probably go with a shim (despite absolutely hating seatpost shims)
reaming for me would depend on how much seattube material there is and how low it needs reamed to.
I'd ask Transition's opinion?
junkyard we're only talking 0.45mm here
Junkyard - 0.45mm!
Ok let's assume it's 34.9mm.That makes the wall thickness 2.45mm. Ream 0.9 mm and the wall thickness is 2mm which is 20% less. Which is a lot.
So it has a 34.9mm seat tube clamp. There are plenty of frames that use a 30.9mm post with a 34.9mm seat clamp (specialised being one)
I'd guess transition specced it with a 30mm seat post for a bit more material and a bit extra strength, personally I think you'd be ok.
If it's decent aluminium and the seatpost isn't super extended when you are pedalling I'd ream it - PITA to do tho.
ST will likely be the same diameter on the outside - 34.9mm
davidtaylforth - Member
Or cos it's crap alu?
All Alu is crap, steel is real and titanium is magic.
I'd be tempted to ream it Tony, it's only 0.9 off the diameter, maybe ask Surf sales and see what they say
How much would you get away with taking off the dropper post?
Maybe take the frame halfway to one of the more obscure sizes (not sure which actually exist but I imagine there is a 30.4 or 30.6 out there somewhere?)
Also if its the 27.2mm route, then you could always try lightly sticking the shim inside the frame somehow, keep the post/shim greased a little and it should stop there?
EDIT:
30.4mm posts if you wanted to ream halfway with the frame and want a normal seatpost for some reason. Would still need to take 0.25mm out the walls of a dropper post though
There's an easy solution:
turn the 0.9 seatpost down to 30.0.
SImples!
If you do just don't sit down too hard
its been done before I've seen a picc some where.
Al will glue one on for you.
hmmmm maybe 27.2 and shim then
Jedi, we've (at 18 Bikes) have done exactly that a couple of times on Bottlerocket frames perfectly successfully. There's plenty of material as the frames are so overbuilt. Just find a descent LBS or machine shop and they shouldn't have any trouble at all
really? oh that is rad!
if i cant find someone local i may pop up. how much?
sounds wrong to ask for a reaming
Yup, done a couple of frames at least. It needs to be done slowly with an adjustable reamer, before using the 30.9mm reamer to get a good job but isn't difficult as such.
Probably be about £20 or so depending on how long it takes
is it a book it in job or turn up and chill for a couple of hours?
Would be better to give us a shout before turning up so we can make sure we have the rights tools at the shop rather than the frame-building workshop
I tried so hard to get the decimal point tin the right place as well
and
Personally I would say its far too much to ream out and you will leave a stress raiser at the bottom of the reamed out section.
I(t might be OK but you are removing a significant amount of strength
Have you got the post yet? I have a 27.2 GD 4" remote post and will be acquiring a new 2nd hand frame with a 30.9 seat tube.
If you have a seatpost of similar or equal radness we could swap or PX and all reamage gets avoided
TJ, the seat tube on a Bottlerocket is hugely over built and is massively thick. There is plenty of room to ream out to 30.9mm without troubles. As for stress risers, I can't see how that would happen at all, especially with careful reaming.
You can get a custom made longer shim from wheels manuf.
I would defo go 27.2 + shim.
You would get a step - a change in cross section where the reamer does not reach.
Overbuilt or not - removing 20% of its strength is a lot.
The reaming is not done in one big hit, it is done in stages and the bottom of the reamer is not square to the tube so end up with a graduated step, not too likely to be a significant stress riser.
Ah well, we'll let the ones we've done in real life speak for themselves
Think I might be inclined to believe what the frame builders/modifiers are saying (18 bikes) on this one
I'd ream it but I think it was an oversight by Transition. It should have had a 30.9mm seatube from the factory, especially as it's designed for what it is.
You must log in to post.
