Just one point which I am not sure has been made. In order to maximise the weight saving that Ti springs offer, you must make sure you get a like for like spring in terms of stroke length.
If you end up with a longer stroke length than you need, then you're effectively carrying more metal than you need and even with Ti being lighter than steel, you negate some of the weight saving.
To illustrate the point, if you have a 2.75" stroke and you end up with Ti spring that is 3" stroke, then the spring has around 10% more material than you actually need.
Often you see spring manufacturers recommending you get the next spring up in terms of stroke length if you can't find one that is exactly right.
