• This topic has 26 replies, 17 voices, and was last updated 11 years ago by hora.
Viewing 27 posts - 1 through 27 (of 27 total)
  • Tips- Effective ways to repair snake-bite punctured tubes?
  • hora
    Every single one I’ve repaired seems to auto-deflate again over night.
    Yes, there is Ghetto tubeless but….for all those tubes that cost me a fiver a pop..is there an effective way to repair a snakebite?
    Houns
    Pump them up harder
    Lose weight
    Go UST
    Buy new tubes
    wors
    learn to repair properly.
    Houns
    Learn to ride properly
    Houns
    binners
    hora
    I pinch flatted the front on a full suss passing a slow rider recently 😆
    rwc03
    Stump up for the gunk and tape (or just use reinforced tape) and use the valves from the old tubes. That’s what I did after debating for ages whether to go tubeless, won’t go back now, rides better and for me the cost is the same compared to what I was spending on tubes.
    hora
    b&q gorilla tape…will try…..on just the rear first.
    Pook
    you pinch flatted the front by having shit technique
    hora
    Muhahaarr. I knew you’d chomp.
    bigyinn
    If you snakebite a tube there’s usually 2 holes in it. Use 2 patches and let them cure properly before using the tube again.
    Patching tubes is hardly rocket science is it?
    trail_rat
    Puncture repair course ?
    Stick on the vulcanising solution then light it with a match , let it burn for a second then blow it out
    Stick patch on .
    Ill be a monkeys uncle if that comes off
    And then when riding inflate your tires more
    wwaswas
    hora’s punctures are all quality control issues by the manufacturer, surely?
    Freester
    learn how to properly repair the holes with a puncture repair kit
    1) find holes
    2) clean tube
    3) quick rub with sandpaper
    4) apply glue
    5) spread glue with finger, nice and thin layer
    6) leave to cure for at least 5 minutes
    7) apply patch and hold it there for a minute
    Pump up gently and check you haven’t missed all the holes.
    buzz-lightyear
    This is what I tend to get wrong due to impatience
    robinlaidlaw
    1) find holes
    2) clean tube
    4) apply glue
    +1
    The biggest potential pit falls are not leaving the glue long enough to dry (when it gets to seeming far too dry to possibly work, it’s perfect) and missing a hole. A full on snake bit may have 4 seperate holes.
    fourbanger
    Am I missing something here? It’s just two holes next to each other. How do you fix a puncture normally OP?
    Mackem
    Buy tyres with protective innards. I havent had a puncture for 6 months. Nobby Nic Double Defense things.
    hora
    Must be a mix of 100kg’s and 30-35 psi. The tubes are probably thinned/as worn as the sidewalls on most of my tyres.
    Ok, I’m not ftting my new chainset tonight. I’m ghetto’ing.
    trail_rat
    Maybe get a new pressure gauge while your at it.
    Freester
    Dude. Yer tubes either let air out or they don’t.
    If you’ve fixed all the holes you are aware of you’ve either not fixed them properly or there is another slow puncture still in the tube. Pop the tube in a bucket of water and go looking for air bubbles – sign of a slow leak.
    sparkyrhino
    cut out the affected area,then staple the tube back together.
    PaulD
    I only patch my tubes at home, in the dry.
    I roughen the tube with a wet+dry block and clean off with petrol and leave to air dry.
    Then put a blob of glue# on the tube and spread out wearing clean nitrile gloves.
    Let air dry.
    Apply clean, untouched patch to middle of hole and radiate pressure outwards.
    Let dry.
    Remove backing paper/clear plastic.
    Dust with talc.
    Fit without levers, inflate and ride.
    # Glue must be the inflammable type…the ‘safe’ glue was useless.
    Do not bother with self-adhesive patches….work of the devil.
    Final thought….100Kg and 35psi (nice mix of units, hey) is either too much weight or not enough air in my opinion.
    I need 27psi with 2.1″ tyres to avoid pinches and only weigh 51kg.
    Check your pressure gauge too, most are weigh out…pun intended.
    PaulD
    hora
    Whistles…
    thisisnotaspoon
    PaulD
    We all know you’re a rocketship uphill, no need to brag about it 😛
    I’m only 6kg off Hora’s mighty stature and use 25-27psi and rarely/never flat. I’m also tubeless, but never feel the rims bottoming out so pretty sure I wouldn’t anyway. Last time I pinch flatted was decending off Skiddaw last summer I think.
    hora
    Alright…I’ll try it.
The topic ‘Tips- Effective ways to repair snake-bite punctured tubes?’ is closed to new replies.
