JohnClimber
I will
Joop
JohnClimber
I will
Joop
You do know that the truss fork is designed for a none suspension corrected frame I take it?
Explosion In a Spaghetti Factory
You think it won't work cause the Moots is sus corrected? I thought if the ac length is the same as for example a Reba it could work..?
I wouldn't imagine the AC length is the same as a Reba though...
You could try it but I'd imagine the truss fork would be way too short and also has too much offset.
I fear you are right and I will have to make up my mind about keep on riding my beloved moots/bs setup or choose the whole jones frameset..
I think they've all gone now and Merlin aren't making any more.
Joop
I've just sent you the measurement of approx 606mm but let Brant and Explosion have their say if it will suit.
606mm sounds very long. Where are you measuring to?
Typical 29er "suspension adjusted" forks are 470-490mm.
I'd have thought Jones would be around 430-440mm.
JohnClimber - MemberJoop
There's something wrong with your tape measure.
AtoC is between 430 and 435. Can't be assed to dig the bike out the pile to measure accurately.
EDIT. good estimate there Brant.
I had the last one
Just measured it - Jones truss fork from the center of the QR to the bottom edge of the headset is 330mm give or take a few mm, headset is 20mm then the headtube start. Good guess Brant. 606mm includes the top section of the truss fork.
Interesting to see what you want for it - they cost $1000 new, but then Jeff wont make you one without the frameset...... and you can't buy one anyway since merlin no longer make them!
futon river crossing - MemberJust measured it - Jones truss fork from the center of the QR to the bottom edge of the headset is 330mm give or take a few mm,
Running 20" wheels there?
Haha yes 430mm my bad!
Sorry I measured from the axle to the bottom of the top head set, I thought that's what you asked me to measure.
I've never heard of the AC length
The measurement you want is aprrox 440mm I hope
Is this the correct place to measure on the updated shot above?
Too bad, it is not going to work with (any) my sus corrected 29er, I need 470mm at least to not mess with my steering; it would work with a 26er and sus uncorrected 29ers though.
But I can always by your whole Jones can't I?
You could build a 69er from that spare fork...... Might be worth advertising it on MTBR classified section. I'm sure there's somebody out there who would want to build up a custom frame based around the fork.
