Thule Lock Removal ...
[Closed] Thule Lock Removal Key
[#2266850]
Where can I get one?
Thank you.
Posted : 08/12/2010 11:49 pm
mines got a number on it so I assume theres more than one, and youd need the correct key.
If not, the locks can be brought seperately, and come with a key or two.
Posted : 08/12/2010 11:57 pm
Check the number on the lock, that's the key you will need. I'd contact thuler directly.
Posted : 08/12/2010 11:59 pm
I have the keys for the locks. I recently bought a set of locks (all the same number) so that I only needed to use one key for all the locks. Problem is that as I bought these locks second hand I don't have the 'lock removal key'
Posted : 09/12/2010 12:00 am
There shouldn't be a "lock removal" key. The regular key is able to remove it as well as lock it.
Posted : 09/12/2010 12:07 am
No, the locks must be in the unlocked position - hence you need the original key, then the removal key must be inserted and the lock will drop out. Mine has a code D1251, which bears no resemblance to the lock number on my eight locks. it just pushes all the pins into the lock body for removal.
Perhaps D1251 is the code number you require from Thule.
Posted : 09/12/2010 12:30 am
djaustin - that sound like exactly what I'm after. With that code and Google I might be onto a winner.
Thank You.
Posted : 09/12/2010 12:33 am
I seem to remember that the same key removed my old locks and fitted the new ones.
So djaustin is right. There is only one key.
Posted : 09/12/2010 1:58 am
Same with mine the key not unlocks it allows them to be removed.
Posted : 09/12/2010 2:03 am
To be honest, I've probably got a spare, they come with every set of locks I've bought. I'll have a look in the garage.
EDIT: greasystain ygm
Posted : 09/12/2010 10:53 am
