Thule aero bars
[Closed] Thule aero bars
[#2259586]
Might be a silly question, but just got some new ones delivered...
Are they supposed to be slightly bent?
If i put them on flat surface then there's 5-6mm gap under the middle.
Posted : 06/12/2010 8:48 pm
Mine are dead straight.
Posted : 06/12/2010 8:53 pm
Think they're supposed to be straight tbh. Both of them a bit bowed?
Posted : 06/12/2010 8:55 pm
So were mine
i'm sure mines have a bit of a bow in them, i will check (once the snow clears)
Posted : 06/12/2010 8:56 pm
Yeah, both the same bow.
Not that the silly pictogram manuals tell you owt.
861's
Guessing that how they should be.
Posted : 06/12/2010 9:03 pm
Same here
Posted : 06/12/2010 9:06 pm
They are supposed to be slightly bowed apparently.
Posted : 06/12/2010 10:31 pm
I think ours are bowed as well...at a complete guess, I'm assuming they are meant to be so that when weight is put on them they straighten (rather than bending) - not really sure why though but that is my thinking...
Posted : 07/12/2010 10:19 am
Has anyone had both aero and standard bars? I have the standard and was wondering whether the aero were worth replacing them?
Posted : 07/12/2010 10:34 am
Yes
For function no difference, for looking better on the vehicle than the black plastic bars then miles better
Posted : 07/12/2010 10:49 am
I prefer the square versions...mainly due to them being cheaper...they do the same job and I'm really not bothered about how they look...I've had square and aero and I honestly can't notice any difference in fuel economy.
I'd have the square ones every time over the aero as they do the same job and cost less...
Posted : 07/12/2010 4:40 pm
aero bars are supposed to look better and make less noise. I suspect that it is 90% of the former and 10% of the latter.
I have never noticed if mine are straight or not.
Posted : 07/12/2010 4:43 pm
Have been putting off getting some bars for a while now but will need them once the snow clears. Where is the best price? All I need are the actual bars themselves as I already have the mounting bit.
Posted : 07/12/2010 4:45 pm
halfords will sell you the bits you need, even if it is just the bars.
IIRC, the bars are the cheapest bit.
Posted : 07/12/2010 4:52 pm
Had both. Epic fail on the Aero bars that left 2 canoes on the M54. I now use Atera:
http://www.atera.co.uk/bars.php
I used to rate Thule products, but I'm not convinced anymore.
Hth
Marko
Posted : 07/12/2010 4:58 pm
