I use this site http://amazingribs.com/ as my prime reference for all things BBQ
I was reading the sidebar on that very site as I designed the initial smoker. 🙂
Meathead’s dream
I have built a hog pit (click here to see my design) but when I lay awake at night I dream of building one of these:
Something big enough to handle a big party and a 200 pound hog, but adjustable so I could cook a few burgers, too. So I’d design a large concrete block or brick rectangle about 8′ long, 4′ deep, and 3′ high. There would be two removable partitions so it can be divided into three separate cooking zones. In one zone I could cook small quantities efficiently, another could be used as a warming oven, an the third could be used to burn logs down to coals or it could also be used as a bread and pizza oven.
Each partition needs a separate lid so it can be closed for roasting, smoke roasting, or baking. Each partition would need its own damper for letting in air, and a vent for letting out smoke.
The food grates for each partition would need to have adjustable height so steaks could be lowered near the coals for searing or raised for low and slow direct or indirect cooking.
The three ash grates should be above ground so air can flow beneath the coals and for easy ash removal.
There needs to be a large work surface nearby and storage for tools.
There should be tables and seating nearby.
Grill, smoker, pizza oven. moveable metal plate to separate the oven into 2 or 3 parts.
You have excellent taste in BBQ websites
