There's a mous...
[Closed] There's a mouse loose in da house
[#1463087]
The little bugger has ignored the fruit bowl and countless other very palatable and easily spoil able foods but what has he done...
Eaten the lids off the sunflower oil and groundnut oil and had a gnaw on some rubber gloves. I have found 2, that's right 2, pieces of mouse poo so this is one well fed mouse as he ain't eating in our kitchen. As we live in a block of flats I've told our agent who is arranging for someone to come in but have discovered whoever installed the kitchen has left huge gaps behind the cupboards and round the edge of the walls where pipes come in out of sight.
I think it's a new addition to the house as the lack of poo or food going missing doesn't show him as being here for ages and neither has it been taking any nesting material. One consolation - with our kitchen being relatively clean we aren't feeding the little bugger someone else is...
Posted : 30/03/2010 9:03 pm
 Keva
you need one of these
Posted : 30/03/2010 9:10 pm
Mousetrap + peanut butter = dead mouse
Posted : 30/03/2010 9:20 pm
Get some mouse repeller plugs. They just plug in and make a very high frequency noise that will scare off the little bugger.
Posted : 30/03/2010 9:25 pm
Don't you mean "there's a moose loose aboot the hoose" or is this some sort of modern gansta moose?
Posted : 30/03/2010 9:34 pm
Keva:
A shed?
Posted : 30/03/2010 9:37 pm
Top marks for the ironic OP name versus thread topic
Posted : 30/03/2010 9:44 pm
GrahamS - Member
POSTED 22 MINUTES AGO # REPORT-POST
I found those a 100% waste of money - just get someone in to kill it.
Posted : 30/03/2010 9:49 pm
Hopefully company that looks after the block will get someone in especially as I've found where the little bugger gets in. Both me and the better half are allergic to cats so I'm contemplating some sort of python...
Posted : 30/03/2010 9:53 pm
Ours have chewed through the wiring in the house 🙁
Posted : 30/03/2010 10:13 pm
I made a humane electronic trap with a sensor and magnetic trap door.
Used a peanut for bait.
Over a few months I caught 37 of the buggers before I found where they got in. Not the same one 37 times because I used to release them when I got to work 5 miles away.
Posted : 30/03/2010 10:20 pm
and at your work someone was getting equally titted off at all these mice so got a humane trap and drove 5 miles....
Posted : 30/03/2010 10:23 pm
[i]and at your work someone was getting equally titted off at all these mice so got a humane trap and drove 5 miles....[/i]
Hilarious! I did that with a mole, took it over the road & the little git was back next day!
Posted : 30/03/2010 10:33 pm
I'm usually really against killing things just because they happen to be inconvenient.
But... we had a rat getting in, there are too many holes in our old house to possibly block them all, and my wife is 35 weeks pregnant.
So to our shame and guilt we got Rentokill in.
But we got the plug-in repellers as a final warning. It only seemed fair.
Posted : 30/03/2010 10:43 pm
I have absolutely no guilt about getting an exterminator in. I'll quite happily gas the little bastard to his doom. If he wasn't in my kitchen I may feel sympathy but if one of us gets ill as a result of him...
Posted : 30/03/2010 11:08 pm
Posted : 30/03/2010 11:10 pm
A story.
We once had an odd smell in the kitchen and it was getting worse. My wife blamed it on her spilling a pint of milk over the oven; some of which must have got into it through the knobs.
Anywhoo, the smell got really bad, so I took the side off the oven to clean it, only to find a [i]RAT[/i] stuffed into the cables and gubbins under the electric hob (must have electricuted itself) Said rat had been cooked over and over again for what must have been weeks.
After disposing of the oven, we ripped out the kitchen units and found a nest and a trail of dog biscuits. This rat had been LIVING in my KITCHEN!!
It is almost certain that my crap (but much loved ) cat had brought the rat in through the cat flap and then let it go; he does this with birds too.
This was a few years ago now and he cant really be arsed these days.
Thankfully
Posted : 30/03/2010 11:40 pm
Dancake - one of my students told me her cat is taking bits of it's food and feeding a rat under their shed. They have yet to catch it...
Pest control coming tonight and I have four traps, some garlic based mouse repellent (worth a try and cheap) and some expanding foam to spray up any mouse holes we find.
Posted : 31/03/2010 5:50 pm
 IA
Wire wool good for blocking up the holes - they can't gnaw through it.
Posted : 31/03/2010 5:53 pm
Rentokill guy recommended usng concrete with crushed glass in it to stop them gnawing.
Posted : 31/03/2010 11:55 pm
The vermin control man has looked around and said there are just so many gaps in the pipe spaces in this block of flats blocking them up would be impossible. He's put down some poison that takes a while to have an effect but apparently dries the mouse out, mummifying him. Hence no smell, or an undead super mouse...
IA - thanks for the suggestion - may put some in my foam which is mostly to block up holes and try and find out how he gets in.
Posted : 01/04/2010 5:59 pm
Apparently if you can get one finger through a hole then it is big enough for a mouse. Two fingers and a rat can get in.
Posted : 01/04/2010 11:26 pm
mouse traps here loaded with a raisin, they can't get them off the tines, our champion raisin has 16 kills and we've not had one for months now, just a few indoors from when the house was vacant I think
Posted : 01/04/2010 11:34 pm
Think I've worked out he/they are getting in behind the washing machine. Bunged up all the hole with foam and gaffer tape so will see if any of it has been nibbled in the morning. Hasn't chewed anything we've noticed although the sudden death of the last washing machine due to an electrical fault makes sense now...
Posted : 02/04/2010 10:10 pm
Hmmm will check the wife out later.
Posted : 02/04/2010 10:20 pm
Mwuhahahahaha! He's taken the bait the pest control guy put in the bottom of one of the cupboards! Due to the ineptness of whoever built our kitchen you couldn't seal this cupboard now as all the pipes come into it and they've just left the back and side off it which now lead directly into the pipe space for the building.
I've also filled every other gap leading into this space with expanding foam so if he does get back in we'll know where...
Posted : 03/04/2010 12:16 pm
