Anybody had this done?
Getting very bored with the various leaks in my air U-turn Team. Despite several rebuilds, they always start losing travle and/or leaking into the lower leg after a couple of rides. So its eally tempting.
However, having talked to TF about it, they basically fit a Pike spring, so max travel goes down to 140mm (no biggy), but I couldn’t get out of them what else they do. At that point the £165 they’re charging seems a little on the spendy side for a spring and a service…
Has anybody else had it done, and are you happy with the results…? (a confirmation of your weight and which spring you went for would also be nice!)
Thanks!
