Few of points to cover.
First, a standard triple now would be 24-32-42, this improves the situation where when you change a gear at the front. you don’t need to make a correction change at the back.
Secondly 29er wheels are bigger and therefore change the gearing, this can be corrected by running a bigger cassette (usually giving a granny gear 2 bigger than what you would have on a 26er) or running a chainset with 2 teeth less on the chain rings 22-30-40, which is what I do because I don’t like big jumps between gears.
Thirdly wide ratio cassettes are in fashion.
ps, the kitten is now dead, I hope you are happy.
