Re: the pole cover, I had been guying it with the guys pegged quite close to the tent, i.e. quite a narrow ‘stance’. I saw someone else pitching with the guys pegged further out (more parallel to the ground) which made sense to me as it braced the pole better against sideways wind.
Also, be careful with the little tensioner straps inside the tent (at either end, between the inner and outer). I was always tempted to tighten these (for no other reason than ‘they looked loose’) but this had the effect of pulling AGAINST the guys on the outside of the tent, effectively loosening the fly and leaving it saggy. now I just tighten the outer guys and leave the inner tensioners loose.
Something I like to do if I remember is to lift the little triangular end panels by looping the elastic chord around the inner tensioner strap, I like to think this helps ventilate the tent a little better.
It’s definitely a tent which benefits from a little practice in pitching. That being said it’s never let me down, even on some horrible windy nights when it’s been battered from side to side all night.
