I’m not sure why people think that the ability to use the “full range” is a big issue? If the chain wrap spec. is 43T, then you simply can’t use any sprocket smaller than 15 with the little ring, so presumably all but the smallest two sprockets (assuming you set up the chain length so you can use big-big to avoid accidents). Using the two smallest sprockets with the little ring is rubbish anyway, so you’re not losing anything there – I can tell you that from experience having broken my gear cable yesterday and being stuck in the smallest cog until I screwed in the limit screw. Our tandem has a theoretical range of 41T from small/small to big/big and that certainly works fine with a 38T capacity mech.
When the OP says “full range” I’m fairly sure he’s meaning in a different sense – ie he uses both the highest and lowest gears possible.
BTW 26/36 is a little bit lower than 22/30, so it depends just how much the OP needs that very bottom gear, or if he just needs something a bit lower than the 2nd bottom.
