- This topic has 40 replies, 24 voices, and was last updated 10 years ago by VanHalen.
Technique question
Orang-HutanFree Member
When riding a berm or even a flat turn with your pedals level should your outside foot be forward? When jumping or setting up for a drop I always favour my right foot forward but it occurred to me that on a right handed turn with my pedals level having my inside foot forward might not be the best for grip or getting on the power directly out of the turn. Any body out there with any constructive advice?
RorschachFree MemberPaging Richmtbguru ,paging Richmtbguru.Mr Guru to the forum please.
EuroFree MemberMy right foot is my forward foot when riding – for jumps, corners, everything really. My pedals aren’t always level mind. I sometimes switch for a change but it feels more awkward. I might be a bit odd though as i’m left footed/handed and my left foot is forward on a skate/snow board. I also air to the left on a vert ramp (can’t do right very well at all).
Sorry, not really advice and might confuse you even more – but if it feels natural then it probably is.
edit 😀 Rorschach
richmtbguruFree MemberRorschach – Member
Paging Richmtbguru ,paging Richmtbguru.Mr Guru to the forum please.POSTED 10 MINUTES AGO # REPORT-POST
Thanks, Rorschach, it’s nice to know someone has faith in my abilities 🙂
Ok then, let’s start this off by saying that theoretically speaking your outside foot on a berm shouldn’t be level but facing down with a good percentage of your body weight pressing down for grip.
Realistically speaking especially with tracks getting more and more technical this isn’t always possible, ie, rocks and roots might be poking out and it might require a quick shifty of the cranks.
I would say that in general your good foot would be the one forward when doing jumps, drops and even going around berms 🙂
The best thing to do is practice this procedure, but also practice with the ‘wrong’ foot forward as well, sounds strange but it is good practice getting used to both feet forward as when being forced into it on a technical descent you will still feel stable on the bike, Go, try it for yourself! I’ve taught this way to a lot of up and coming downhillers, it’s a vital tool for downhillers! Keep safe, and always wear your helmet. 🙂JunkyardFree Memberbest foot forward if a jump is coming but you should be able to do both ways whilst favouring one in general. I reckon i could comfortably do 70% of trails either way- not that either way is necessarily fast
ianvFree MemberSome French punter giving advice on cornering:
[video]http://www.youtube.com/watch?v=gF5K9V2w6W8[/video]
EuroFree Member…also practice with the ‘wrong’ foot forward as well, sounds strange but it is good practice getting used to both feet forward as when being forced into it on a technical descent you will still feel stable on the bike, Go, try it for yourself! I’ve taught this way to a lot of up and coming downhillers, it’s a vital tool for downhillers!
Pump tracks are a good place to practice with the wrong foot forward, right coach?
theotherjonvFull MemberOutside pedal down for corners. Made a huge difference to my cornering ability.
RorschachFree MemberYeah….no actually.
Could’nt find an ironic face,I’m also of the opinion that you’re an ego maniacal socio path.mrblobbyFree MemberBlimey, and I thought that outside pedal down (especially weight on that pedal) lifted the bike up and that pedals level was the way to go. Also find level pedals necessary for pumping the berm. Though I’d not dare go against richmtbguru’s advice.
Edit: zut alores, that French punter is talking more about corners than berms, and a berm isn’t really a corner 🙂
Yeah….no actually.
Could’nt find an ironic face,I’m also of the opinion that you’re an ego maniacal socio path.POSTED 17 MINUTES AGO # REPORT-POST
I think I will be pressing the report button..you also need help with your literacy!Orang-HutanFree MemberThanks for the input richmtbgur. MrBlobby understands where i’m coming from though, berms are different from corners and level pedals feel right for me for that pump mid berm but when I reach the end and want to pedal out if my inside foot is forward its easy to pedal strike the ground and lift the bike off the ground. I could do a half pedal backwards but backwards pedalling is never a good idea imo.
buzz-lightyearFree MemberOk then, let’s start this off by saying that theoretically speaking your outside foot on a berm shouldn’t be level but facing down with a good percentage of your body weight pressing down for grip.
Even this seem contentious and I’ve had mixed advice and result. Flat corners: right on. But specifically why is it important to find more grip on a banked corner than is already conferred by the banking? Is it not the case that pumping and fast flicking between corners is virtually impossible with dropping one foot down, esp. with saddle at normal height? And as you point out, there is the issue of striking a dropped pedal and being tossed into oblivion. Been there, done that, which is why I reverted to level pedals cornering in situations where grip seemed less of an issue!
Can you explain?
zilog6128Full MemberMy right foot is my forward foot when riding – for jumps, corners, everything really.
This (pedals level when corning) was the first thing Jedi noticed about my riding and was, in his opinion, a big no-no.
Jedi teaches outside pedal down for all cornering for (worryingly) exactly the reason Rich mentions.
No, you get much faster with practice. If your saddle is getting in the way, then it’s too high. Dropper?
theotherjonvFull MemberMy info is also result of a session with the jedi man himself
richmtbguruFree MemberEven this seem contentious and I’ve had mixed advice and result. Flat corners: right on. But specifically why is it important to find more grip on a banked corner than is already conferred by the banking?
Sorry I mis read, and you are totally right about being level on the banked berms is ok but not good practice, I just had flat berms in mind, my fault, sometimes even we get it wrong, but only because I completely mis read, yes a banked berm at speed will have a gravitational affect… Really sorry but I still feel a little upset at how Rorschach spoke to me earlier, especially thinking he we being sincere to start with. 🙁
zilog6128Full MemberBut specifically why is it important to find more grip on a banked corner than is already conferred by the banking?
It might not be 100% necessary to have the extra grip but why get into the habit of taking certain corners with a sub-optimal technique? If you have trained your body & brain to put the outside foot down around all corners then you just do it without even having to think about it.
EuroFree MemberThis could get a little confusing. Zilog, you can weight the outside foot with the pedals level/levelish and get the same effect as having your outside foot right down. You can weight the inside foot in the same way. Maybe your coach noticed that you weren’t doing this, so got you to exaggerate the movement in order to get your weight and body into the correct position? It’s a good technique to have, but it’s not the position of the pedal that matters (unless there’s something for the pedal to strike) – it’s how you transfer your weight through it.
oldnickFull MemberIf you are going to go round a corner with pedals level I would lead with the outer foot so as to help turn your hips into the corner.
Outer foot down usually though 🙂
zilog6128Full Memberyou can weight the outside foot with the pedals level/levelish and get the same effect as having your outside foot right down. You can weight the inside foot in the same way.
I suppose so! But of course for flat corners you get maximum pedal clearance with outside down/inside up, and it makes sense (to me) to take all corners with the same technique so it becomes instinctive.
mrblobbyFree Memberso got you to exaggerate the movement in order to get your weight and body into the correct position? It’s a good technique to have, but it’s not the position of the pedal that matters (unless there’s something for the pedal to strike) – it’s how you transfer your weight through it.
I think this is probably true and that it’s more about weight shift and body position, and lowering the outside pedal helps get things moving (but you don’t actually need to lower it much – if you look at some of Fabian’s video he’s not lowering that pedal much, other than when he’s deliberately demonstrating the technique.) Find if I lower it all the way I lose both the ability to pump and to soak up the bumps (may be less of an issue on a FS bike.)
EuroFree Memberdown/inside up
Yeah, it’s the right way to do it if you want to stay on 😀
The type of corner plays a big part too. Some corners need the foot right down while others allow you to get away with less which kinda suits my ‘hang off the back a bit too much, but i can’t help it ’cause i’ve long arms’ riding style as it pulls me forward a bit. Might just be a tall rider thing and not useful for everyone. Or might just be me 😀
EuroFree MemberWe’ll leave fore and aft weight distribution Lvl II for another thread 😉
mrblobbyFree MemberWe’ll leave fore and aft weight distribution Lvl II for another thread
Found riding a stiff hard tail sorted that out for me!
benjiFree Memberbanked berms is ok but not good practice, I just had flat berms
Am I missing something, or are not all berms banks round corners, and a flat berm would just be a corner. Explanation with pictures would be great.
My better technical mate, used the old hans ray of chocolate foot always lead with your chocolate foot, i.e. the one which you prefer.
SuperficialFree MemberI often corner with a half-and-half foot position.
I.e. my right (chocolate) foot in either the 1-2 o’clock position (for turning right) or the 4-5 o’clock position (for left hand corners). Rarely in exactly 3 or 6 o’clock.
For perfectly flat smooth corners, I suppose 6 and 12 is OK. Likewise, for smooth berms with no features, 3 and 9. But MTB is never like that.
FWIW I’m trying to learn to corner ‘wrong’ foot forwards which I find harder. But useful skill E.g. mid-way through a pedal stroke.
oldnickFull Member“you can weight the outside foot with the pedals level”
Really? Whenever I do that the pedal goes down to the bottom, unless I’m pressing the inside pedal just the same amount.
Must be something wrong with my bottom bracket.
chiefgrooveguruFull MemberThe fundamental thing with all this cornering malarkey, is that you need to shift your hips outwards. Everything everyone says about weighting/dropping pedals, twisting hips, pointing belly buttons, looking where you’re going, inside hand down, lean the bike, is all just symptomatic of the big move which is the lateral hip shift.
If you’re horribly stiff like me then you try to do all of those things and it still doesn’t come together quite right. Then you try to just focus on shifting the hips and immediately everything falls into place and the bike rails corners, right, or left, and when the drift happens you’re so much more balanced as the bike drifts into you and you can adjust, rather than the bike skidding away from under you. If you can ski, just do what you’d do on skis and the bike will lean and turn.
Getting comfortable with swapping feet is definitely a good thing too.
stumpy01Full Memberrichmtbguru, can you explain what you mean by ‘flat berm’ as opposed to ‘banked berm’?
I thought a berm is a banked corner, so how can you have a flat one? Isn’t that just a corner?stilltortoiseFree Memberyou need to shift your hips outwards
I don’t follow this and can’t picture it. Unless skiing technique from beginners to pros has changed massively since I last looked, surely these two statements are completely opposite ends of the hip-shifting spectrum. I need to unread this so I don’t have a horrible crash trying to do it 🙂
…unless I’ve completely mis-understood what you’re trying to say. Can you expand?
breadcrumbFull Memberbanked berms is ok but not good practice, I just had flat berms
I thought this too. Odd.
akiraFull MemberPoint your hips in the direction you want to go is a better way of describing the hip action.
ddmonkeyFull MemberI think you’ll find Mr Barel has got it covered in that vid – outside foot and in particular heel down, lean the bike not your body, outside elbow high. The flatter the corner the more you need to exagerate the action to acheive the turning effect. Bermed corners need less effort to turn the bike for a given speed but hit them faster and you will need to hold the body position to control the bike and hold the exact line you want through the corner. Don’t touch the brakes once you are 1/3 of the way through the corner and the bike will accelerate out as it unloads. Mr Barel would also say think more about flow and less about getting on the pedals ASAP.
SOAPFree MemberOnly ever outside down on flat corners or if I’m not going to make the turn on a berm.
For berms pedals level use your speed and commit to the berm trying to keep your bike at 90 degrees to the berm/bank,big or small even a rut you can use.
Never inside down or you will die.ianvFree MemberMr Barel would also say think more about flow and less about getting on the pedals ASAP.
[video]http://www.youtube.com/watch?v=CSSi7n9RlHc[/video]
[video]http://www.youtube.com/watch?v=6ZKhkyoOcdg[/video]
MugbooFull MemberI think it all gets confusing because coachs like Jedi teach outside foot down but watch a lot of the pros riding and they to corner, pedals level a lot. (Not a pop at Jedi, enjoyed a day in his company 🙂 )
For an example of riding like skiing, Danny Hart in Champery!
devsFree MemberAs I was a skier before I was an mtber I used to try and use the skiing analogy but, whilst it helps initially, it’s wrong in my opinion. The main problem is that a good skier will always be facing down the fall line no matter which way he is turning. In mountain biking the more effective technique is to shift the whole body above the outside pedal and face the exit point of the turn. This means you can be side on or even slightly back on to the fall line for a period.
dantsw13Full MemberPedalling on berm exit with the bike still leant over unweights the front wheel, losing grip, and leads to imminent death!!
If your saddle is low enough, you can drop your outside pedal, but still remain enough leg flex to absurd bumps/roots etc.
The topic ‘Technique question’ is closed to new replies.
