I’m hoping someone cleverer than me can help me determine what size hole to cut in my worktop for my new electric hob..
I understand dimensions C and D in as much as if you have a tiny strip (40mm) on one side of your hob you need to have a reasonable length on the other side (min 200mm), happy with that.
Now the dimension that says 750/780 is confusing me. At 1st I thought the installation instructions were for two hob models but it seems not.. I have checked the physical hob and 750 seems more appropriate after getting the tape out (it is also smaller so I will go for this naturally 1st if I don’t get any further with my understanding..) but I want to know what the 780 is all about.
Similarly A and B confuse me a little.. I understand if you cut a bigger hole you’ll have less at the back and vice versa for a smaller hole you’ll have more at the back. But not sure why the hole I need to cut should ever change size!
Any help would be much appreciated before I set about butchering my new worktop..
Thanks
[url=https://flic.kr/p/rDGQHL]Hob_Cutout[/url] by VeeeDubStar, on Flickr
They are tolerances. 750 will be snug, 780 loose. Building work and kitchen fitting isn’t precision engineering. It should have a flange that covers the difference. If you do it too tight then you won’t be able to move it a little to get it square. I’d certainly aim for the smaller sizes though.
Otherwise I reckon that drawing does apply to two different hobs, hence the 750/780 and 490/500 dimensions.
I’d measure up the actual hob, rather than relying on the drawing.
This I think too.
Crikey though, I understand companies’ needs to only have to print one set of instructions for everybody in the world, but that could be made a bit simpler. 😕
Minimum worktop depth front to rear = 600mm
Minimum overhang to front/rear of cutout after cutting = 50/60mm
Minimum distance to left/right of cutout after cutting =40/200mm(for tall unit or other appliance)
Minimum insertion depth = 35mm measured from top of worktop.
Cutout depth front to rear = 490-500mm depending on model with a tolerance of +2mm maximum oversize.
Cutout depth left to right = 750-780 depending on model with a tolerance of +2mm maximum oversize, no tolerance to be undersized hence the 0.
It’s for 2 widths as said – I studied technical drawing but am not a kitchen fitter…actually I did fit one and got a mate to cut the how, the sink came with a template.
Thanks for the replies all. Hob hole now cut and fits well at 750mm wide and 490mm deep.. It transpires that the 780 width is if you want to use a spacer bar of 15mm either side which was not really made clear in the instructions. The spacer bar did not come with the hob and I’m not sure I see the point TBH!
Posted 9 years ago
Viewing 16 posts - 1 through 16 (of 16 total)
The topic ‘Technical drawing interpretation’ is closed to new replies.
