Hi guys, can anyone help with a weird problem?
Got a mates bike I’ve helped him change the bb with. It’s a raceface cinch system.
Its a 73bb threaded bb shell so we’ve put one 2.5mm spacer on the drive side cup.
When the drive side 8mm bolt is up tight there is still a fair gap on the non drive side.
You are supposed to wind the side tension thingmybob up to preload the bearing laterally but when you do it screws off the end of the threads because of the gap, before you get it to bite up.
I’ve thought we could add a spacer on the non drive side cup but will that mean the internal sleeve let’s muck into the system from and water that’s increased in the frame?
Anyone found similar and got a good solution?
