I’m just about to start building a tallbike this afternoon.
I have 2 steel frames, one in good working order(ish) the other with just about everything seized into it. So the bad one is going on top.
My idea is to have a chain goijg from the big ring on the top frame to the big ring on the bottom, then from the middle ring to the cassette.
Then to drill the stem on the bottom and remove the bars and feed the skewer from the top forks through the hole, rather than welding tubes onto steerers and all that, as one is 1 1/8 and the other 1″, plus as I said it’s all seized up.
Anyone got any handy tips from experience? I’ll be using a tig welder with mild steel rods.
