Hi all,
More DIY…
Putting together a small box, mix of pine and plywood. The main piece will be dark, but a couple parts fitted later will be a lighter shade. Would like a smooth satin finish.
I understand a sealer is required to get an even stain, especially with soft wood.
So I’m thinking
– Seal both the main piece and the other parts.
– Stain the parts either dark or light.
– Glue the light parts to the dark piece, being careful not to get glue on visible surfaces.
– Once glue has set, varnish complete box with clear satin varnish.
That all seems fine. However, the more I read into it, the more confused I get.
– Do most stains now-a-days incorporate a sealer in them?
– Once the wood is sealed, does the stain act more like a paint, in that it covers the grain?
– Does the sealer, stain, and varnish need to have the same base (water or oil)?
– Oil based is more durable I believe?
Thanks,
Duane.
