london_lad_liam
does the coil give a much more predictable ride compared to the air?or more plush?
Well to start with there is the reliability issue. In my experience I’ve had far less issue with coil forks and shocks than with air. Maybe just me. I’ve never experienced an air fork that felt as good as coil, never.
Then on a dh/fr bike you have the diving issue – you want it plush, so you need to lower the air pressure, but as you spend most of your time with the bike pointing downhill it sags excessively. Something I noticed on the earlier totem airs. Cant see it being fixed. Maybe I’m just a luddite but I don’t trust air for dh applaications. The difference in weight between a totem air and coil, or a lyrik for that matter is negligable (sp?)
Stick a ti spring on the rear and you’ve got the best of everything. If you avoid cheap parts it can still be a sub 36lb build and be all coil. I ran a 170mm lyrik on mine before swapping it for a totem – the geometry felt ever so slightly better but the steering improved dramatically!! It is so stiff and just track much much better. Totem coil all the way!
