Trek Superfly FS 100 2013 bought as frame
Fork: 2010 Rebas with pushloc
Rear: RS Monarch RL
Rider weight: 86kg
Current fork pressure: 105psi in both chambers
Current shock pressure: 155psi
1) At lower pressures the fork is supple but has too much sag and dives too much, but at higher pressures (120) it’s too firm and knocks me off line (slightly) on steep rocky bits.
Does one run less in the -ve chamber than the positive? Should I use lighter oil, since I cannot reduce compression damping? Should I put some oil over the piston to make the rate ramp up? Or perhaps oil *under* it to reduce -ve chamber volume?
2) This is more annoying – the shock never goes near full travel and just ramps up too much, even if I set the pressure so low that I get too much sag and it wallows. It still ramps up. Am I likely to find tokens in it?
The shock may not be original since the picures I can find of the bike have a Fox shock on, so it may not be optimatlly set up.
