Superstar floating ...
[Closed] Superstar floating rotors - any one used/rate them??
[#3495418]
Thinking of purchasing a couple of these for my commencal - anyone had any real world experience of them? I need some new rotors for it anyway and they seem to be a cheap upgrade compared to factory rotors. Currently running hayes 9(i know they're old but i love them!) with 203mm front and 180mm rear.
Posted : 26/12/2011 11:35 pm
Had a set earlier in the year, the bolts/rivets that connect the inner spider to the outer rotor sit proud of everything else and fouled on my brake caliper.
Superstar know of the problem but dont put a warning on the description/advert for this item, their helpful response was to advise me to file away the part of the caliper that was catching on the rivets.
I decided not to bugger up my brake calipers for the sake of some cheap floating discs. To be fair to Superstar they replaced and refunded them with a normal set of rotors instead.
My brakes are Shimano so its not as if i was using some obscure boutique brake brand.
I found i could improve my brakes in a more cost effective fashion with soft compound pads instead.
Posted : 27/12/2011 11:18 am
my hope ones were like this too
Posted : 27/12/2011 11:25 am
What's the benefit of floating rotors?
Posted : 27/12/2011 11:40 am
they look nice.
I have them on one of my bikes.
Posted : 27/12/2011 11:43 am
 DT78
Colour
meant to help keep things cooler and help stop the rotor from warping when things get hot
i'm running a pare of 180mm with avid codes no issues
Posted : 27/12/2011 11:44 am
deviant - which shimano brakes have you got?
I'm looking at trying to fit them to some old M755 but very reluctant to, if i'm going to have to start making mods to the caliper 🙄
Posted : 27/12/2011 11:57 am
They make an ace ticking noise when cooling down
Posted : 27/12/2011 12:01 pm
Windydave, they're Shimano M575 brakes.
Posted : 27/12/2011 1:45 pm
Cheers fella. I might just give it a whirl and see. They can always go on the already bodged singlespeed!!
Posted : 27/12/2011 2:07 pm
hungry monkey - Member
Yep - Hope floaters can have the same issues with the 'floating rivet' not clearing on certain callipers.
It's a simple fix with only a tiny amount of filing required - which won't mess up up your brakes.
Posted : 27/12/2011 2:38 pm
There's not a massive difference between them and shimano, I wouldn't bother, tbh the superstar ones look rubbish.
Posted : 27/12/2011 2:46 pm
