Viewing 14 posts - 1 through 14 (of 14 total)
  • STW spiderologists- what are these bad boys?
  • kerv
    Found them in a manhole at work.
    jam-bo
    Definitely spiders. hTh
    kerv
    Nope.?
    kiwijohn
    Red backs or relatives of.
    kerv
    They don’t look like the pictures of red backs I can find, no stripe on the back.
    roper
    Can you post some higher resolution photos?
    The thumbnails are too small.
    kerv
    Sorry Roper that’s testing my IT skills too much! They were taken on a mobile and uploaded to Flickr, I’ve no idea why they are only thumbnails.
    roper
    At a guess I would say Meta menardi or a cave spider. They are common in very dark spaces through most of Europe. They have quite a strong thread and tend to hang their egg sacks from a ceiling. So if you see white cotton ball like things hanging down , that’s what they are.
    I’ve found them to be quite docile but wouldn’t play with them as they do have largish jaws.
    See if these look right
    https://www.google.co.uk/search?q=meta+menardi&biw=1280&bih=856&source=lnms&tbm=isch&sa=X&ei=qiTFVKGjNMn9UOLaguAH&sqi=2&ved=0CAYQ_AUoAQ
    Cougar
    The second thumbnail is clickable.
    kerv
    Cheers Roper some of those images look like the same creature, hopefully you should be able to see the second image now and that shows the cotton ball exactly as you explain it.
    john_drummer
    I’m no expert but is the second one a False Widow?
    timba
    Orb weaver spider Meta bourneti?
    Quite rare depending on where you are (BBC news)
    kerv
    [url=https://flic.kr/p/qTtoC9]image (1)[/url] by Kerv F, on Flickr
    Bigger version of the second image. They were both in the same manhole at work, just outside Milton Keynes. There were a number of the cotton wool balls in the manhole. They looked a lot like the ones in your link too timba, and about the same size. Normally in pitch black with the lid on the manhole.
    timba
    I’m no expert, but apparently you need to be to tell Meta bourneti and Meta menardi ^^ apart
    BAS contacts
The topic ‘STW spiderologists- what are these bad boys?’ is closed to new replies.
