Was after a PIR outside light fitting to the house, and an underfloor heating controller moving and wiring in . So i contacted a local electrician and they sent out an engineer to see what needed doing . He surveyed the work and a written quotation arrived about a week later.
I was happy with the price and wanted the work doing so i contacted them and said to proceed with the works.
Got an email last night saying an engineer would be in today to do the works.
Got home from work and its all gone very wrong. The dullard has mounted the light at eye level, so you are half blinded by it as you walk toward te steps its supposed to illuminate ,and its only 60w bulb.
To get the power feed he spurred off the celing rose inside the porch.
I guess he used a 300 mm long SDS to drill trough at an angle as a rather large lump of plaster has been smashed off the inside wall. He was supposed to get the power from the porch light switch, but apparently that was not possible.
So he took the feed L + N from te ceiling Rose. This is switched live . So to make the outside light come on you have to have the porch light on . Which shines very nicely through the glass door out onto the steps, negating the need for an outside light . I can have a PIR outside light , only if i leave the inside porch light on for the rest of my life.
I can take the bulb out of the porch lamp , and then the PIR will work, but I wont be able to see in the porch as the PIR outside will not come on till i go out, then come back in to lock the door / tie shoe laces etc, and as light does not go round corners the spill wont fill the porch at all.
What I dont know is why the guy just didnt fit the outside light and do the other jobs. Or why not grab the N wire from the celing rose and feed it through with the permanent live from the wall switch .
Thus giving a switchable porch lamp , and a PIR activated outside light .
and i haven’t even looked at what he has done with the heating controller, I am expecting blue tack and sellotape fixings…
