I have a HOPE Pro II front hub and Marzocchi forks with 20mm bolt through.
Before, to remove the front wheel, I’ve undone one of the side bolts and, with a little wiggle of the wheel, the axle slid out of the other side.
However, now, the axle rotates but won’t slide out. The front wheel spins freely. I have undone the pinch bolts.
I’ve tried half undoing one of the bolts and smacking it several times with a mallet (hard). The axle moved about 1mm.I tried spraying WD40 on it and then malleting it again but no joy.
I don’t want to damage the bearings or axle. I live in Thailand and can’t get spares until the end of March.
Thanks a lot
