Exactly what tron says – I had this when I first fitted a Panaracer Fire XC Pro to my front wheel with a disc brake. The Panaracer went on the rim easily enough, but the tradeoff seemed to be that it was sufficiently loose to slip around and rip the valves off the inner tube.
In no particular order, I tried: reinforcing around the valve stem with some old inner tube; talcing the inside of the tyre extensively; trying different inner tubes; replacing the tyre with a Bonty Jones ACX. All except the last worked somewhat (as in seemingly alleviated it for a couple of rides but still led ultimately to the same problem).
Having said that, the Bonty *did* rip one valve off an inner tube, but only once. Weird. The bead of the Bonty is much tighter than the Panaracer, so that may be part of its strength
In summary then, talc, perhaps try some brand-name inner tubes, try to check how tight the bead of the tyre is on the rim, and if all else fails, try a different tyre.
