if its on top of a constructional hearth (125mm minimum concrete) – then you dont need anything at all though – the tiles are merely to diferentiate between your floor and the hearth – satisfying the clearly marked boundary required under regs.
as long as what you use is non combustable it doesnt matter how thick – when atop a constructional hearth.
its 12mm minimum if your stove qualifys for the thin hearth.
ps as an aside – has anyone found a stove that heats the surface under to high temps ? laser thermometor says that neither of mine(neither approved) can heat my floor up to any where near 100 – even after being roaring for hours and the room being at 25degrees 😀 – at which point i come in and open the doors and vents to let the heat round the house and get moaned at for creating drafts 😀
also i found this in the stove fitters manual a while back and thought it was a peach.
“Note: You will see stoves with log stores underneath. These stoves must not, if building regulations are to be adhered to, be lit whilst logs are in the log store (’tis true).”
