Hi,
Some scumbags have smashed open a shed and stolen my Cotic Solaris last night (Friday 17th/Saturday 18th) from the Twickenham area.
If anyone seen anything coming up that matches the description, please drop me a line as I’d like it back (to say the least). Spec (which should be a bit of a give away) is:
Cotic Solaris Mk2 – Large in Gunmetal
X-Fusion Slide RL2 120mm Forks (white, 15mm bolt through). Has a J-Tech sticker on them.
Hope Pro 2 Evos hubs with Stans Flow Rims. 15mm Front, 10mm Bolt through (ST Swiss) on the rear. Continental Trail King on the front, Mountain King on the rear – both tubed.
Praxis Works 11-40 10-speed Casette, SLX Deraileur. XT RH Shifter mounted (i-spec) on SLX brakes.
SLX crankset with Absolute Black Oval 32t chainring (single).
Reverb Dropper with Fizik Gobi Saddle. Dropper remote mounted on left hand side.
Easton (brand-new) Havoc Carbon bar (750mm wide). Lizard Skins Moab grips.
They’ve also run off with a Large Specialized Diverge Elite DSW – pretty much stock. Black with Red accents. Bought in December – 600 miles on that one.
I’ve got the Frame number for the Diverge – and typically can’t find where I saved the frame no of the Solaris.
Once I work out how to put pictures up (used to be able to, now have no idea…) I’ll put up some snaps.
Thieving Scumbags…
Cheers,
Rich
